God you’re rightWhat would you do without two EVs?
)Cool so pretty much the cataclysm with a separately switchable modulation added in?
Personally I think the bigger enclosure tradeoff just to get a footswitchable modulation is not worth it.Yep. I haven't decided if I want to go 1590BB with modulation footswitch or 125B with a single footswitch.
How often would you want to turn on the modulation by footswitch?
Definitely. Also now that I think about it, I rarely use the dark rift for all the crazy things it can do. This pedal might actually be a decent replacement for the two of them on my board. I’ll always keep the dark rift but for board space I like thisIt might actually replace the Cataclysm project since it's essentially the same thing with modulation.
Turn Depth all the way down and it's identical.
If it goes into a 125B there's no reason to keep both projects.
Assuming the modulation would instead be put on a toggle switch, it would be easy enough to wire up the modulation switch off-board for a footswitch if someone is so inclined. I vote 125BYep. I haven't decided if I want to go 1590BB with modulation footswitch or 125B with a single footswitch.
Now just a consarned minute!
Opened up my Dracarys with the intentions of tracing it, or trying to anyway. It has a couple hundred parts, so I closed it back up. Too many to fit into a 125B, more than I want to try, anyway.
Hey thanks for the heads up. Do you think you can fit it into a 125b, or a1590bb?I traced it a few months ago, it's in line for a layout sometime in the near future.
Be careful if you aren't familiar with SMD film caps (it has quite a few). You can't accurately measure them in-circuit but they're plastic and will melt almost instantly if you hit them with the soldering iron.
