Untro
Hey gang, I think I need some help with this run of LGSM I just finished. After a long haitus of the hobby, I finished three I had started months ago. Two worked, one with a lot of fanaglling, but the third...
The third had one pot that had lugs, and i forgot to heatshrink those lugs. When I tested this pedal (outside of the enclosure), it created a screaming self oscillation, the LEDs in the circuit glowed bright green, and then it stopped making any noise at all except a soft rhythmic 'chck chck chck' kinda sound. I wonder if the lugs on the wired pot shorted against the board in a critical way. It still passes dry signal.
I really want to learn how to fish when it comes to trouble shooting. It had been awhile since I had made a pedal and I forgot some of the finer points of offboard wiring, but I've gone over the parts again and again and everything looks correct, the points on the pcb look fine. I know I'll need another tlo72 and diodes in there, but want to make sure I dont just short another.
I don't know how to trace or measure signal or how to compare what's what, I've tried to learn but it just eludes me. Any outside perspective/advise on this one, or leads to resources that worked for you when it comes to learning troubleshooting, I'd very much appreciate it.
