Could we build a Honey Bee with a dual op-amp chip?
HamishR
Being based on the Rat pedal the Honey Bee uses a CA3130 single op-amp chip and a 2N5457 JFET. To over-simplify it's a two gain stage pedal. Could we make it with a dual op-amp chip like the TL072 etc? Obviously it won't sound exactly the same but how close could we get? And is there a dual op-amp chip which is like two CA3130s in one package?
Just curious, as always!
Having built both, the sweet honey sounds quite a bit different to me. But I think that’s mostly due to circuit. Should be able to do the main part of the circuit just like the honey bee, then make the last op amp a simple booster.
I don’t know if there’s a similar sounding dual chip, might be interesting to drop a TL071 into a bee and see how different it sounds? You might need to remove the 100pF from pins 1 to 8
