Roast My Build - Brown Betty
GizzWizzKing
5.00 star(s)
ROAST MY BUILD!
Sometimes it gets pretty chummy around here. In the spirit of IAIGF, tell me why this build is hideodorous! So ugly it stinks.
I think the sounds it makes into a clean amp make it worth the bigger enclosure. The great component layout made this a breeze to populate in rows. I'm starting to really enjoy the zen of soldering. I use Lead-Free solder.
Substitutes:
- Presence -> B10k.
- C8 -> 270pF
- C9 -> 220pF
Posca Pens on Tayda black sand with Tayda knobs and a UV LED. Drilled by myself. I will maybe add more art and pop to the text later.
Edit: Officially the most overspray I've had to deal with on a Tayda enclosure. Sanding around my jacks and pots was a real pain. also only 2 of the screw holes were drilled out well enough to use. It looks like the other 2 were done at an angle and have so much overspray that it makes them impossible to use.
Your foot switch is upside down. White washer goes on the outside. Too many - and ugly - knobs. Needs more Wima caps. Should be in a 125B.
There’s a bigger question here.
Why can’t you decide between a BE-OD and Dirty Shirley? 🧐
Shit or get off the pot!
  • Like
Reactions: spi
This pedal looks like it was designed by a kindergarten class during arts and crafts time, using whatever was left over from a glitter and glue explosion. The knobs are more mysterious than an unsolved murder case—who even knows what "Tighx" does? It's probably a secret setting that makes your guitar sound like it's being played through a tin can. The meteor theme is a nice touch, though. It really sells the idea that using this pedal might crash and burn your entire rig.
