bretvh
Ok, so my last two builds have been a little more challenging than usual. With this one, I was extra cautious—I verified each resistor and cap to verify I was grabbing the correct ones. I am pretty confident those are correct. Of course, I could totally have overlooked something, so any catches will be much appreciated. Here is what I have done so far:
- I am getting what appear to be proper voltages on the TL072 and the HT8950.
- When I trace the signal, it craps out just after the 1M variable resistor where it connects to R2.
- I am getting a clean signal on Pin 2 of the TL072, but no output on Pin 1.
- I have swapped out the TL072 a couple times, just to be sure.
- When I probe the center pin on the variable resistor, the signal is weak, slightly distorted, and there is a high-pitched squeal present.
- I have tried measuring and moving the VR and it appears to be "working" in the sense that I can see the resistance change within expected ranges. Yet, there seems to be something amiss in that area of the circuit.
