Technatured
I did up a build of the abider, but the output was crazy loud. Had to keep the volume almost off to keep a useable volume. Anything above just cracked open causes a huge boost in volume and the entire pedal goes microphonic.
Went through the whole board of parts, and got to lower resistance across multiple resistors (R12, R16, R20, and R21). I was reading 12.4k across R21 which should be a 20k, others were a few K ohm less than what was spec’d. Removed R20 and it reads 20k, but reading 33.3k across the empty pads for R20. With R20 remover, R12, R16, and R21 read correctly. All ICs and Transistors are currently removed, as are input and power Jacks.
I’ve gone over and reflowed all my joints, but with no change. Any insight is appreciated. Gunna have to step away to mow the lawn and try again with fresh eyes in about an hr. I’ll attach the schematic file for anyone to take a look. Note that the correct layout is in the build docs, and not the image on the PCB listing on the site.
