hoping to get a bass rolloff knob to the delay'd signal. it's just so murky, and i'd like to be able to dial that out a bit. other schematics have a passive filter either before or after the mix control.
the cataclysm delay has a BMP style tone stack, and that's too much. electric canary's iridescent has a high end rolloff. so it seems easy enough to just tack into place. am i overthinking or underthinking this?
If you’re looking into missing it I would probably put it in a breadboard and do some
Experimenting that way. I’m sure you could implement something like that.
in the gravitation reverb it cuts bass. or rather that's the sound we hear. very well could be adding it.
I'm just throwing mud at a wall at this point because I've tried a couple things and none have worked and this thread went unanswered.
if I go from the pad that should be pin 3 of the mix pot to a HPF, which feels like it should be cap to leg 3 of a pot, leg 1 to ground, where do I get back to pin 3 of the mix control? or can I just take it onto pin 3 of the mix control?
the pedal is already built, so there's no breadboarding I can do. just want to know how to add this one control and I'm gold
Stumbled across this thread again. Sorry, I must've been asleep when I posted here previously; I definitely didn't get the gist of it before (and it's really not that hard to do so). Maybe I was fixated on the reverb or something, and my own use of two caps on a pot, which is usually to add bass on the input of something, not to bleed it off...
Anyway... SEABED DELAY, not Gravitation Reverb.
Yes, adding the Gravitation-style thing could work on the SEABED delay repeats; did you try implementing it and if so where?
Pin 3 is feeding the repeats back into the board, so...
A cap to replace the leg of the pot's pin 3, then a resistor from the board's pad to ground.
Snip leg 3, get out some alligator clips and experiment with values until you've got what you want.
Lots of great PT2399 designs out there….. I have tried a number different variations and have built what I consider a best performance design, using a compander, elaborate filters, etc. I hav…
"The 'Blueprint Bright' made a simple modification to cut bass response into the delay to produce a brighter overall tone."
If you've got or know someone who's got the VFE Motherload schematics, it might be in there. If not, check out the schematic in the MadBean PDF of the regular Blueprint, as it has "An internal trimpot allows you to adjust the blend to brighten or darken the tone to your taste."
That just might be your solution, shoe-horn the VFE trimmer into your Seabed.
so i finally understand part of what my issue was. i was trying to add this to the mix control, not the end of the repeats.
pin 3 of the repeat pot is going to a 33n, then a 5.1k, then to pin 1 of a 10k pot. pin 2 to ground. pin 3 to the repeat return (formerly pin 3) on the board. annnnnnd i've finally got delayed signal, but it's a single repeat no matter where the knob is and the filter i've created is having no effect at all. what do i have wrong this time?
simplified it significantly and followed the diagram you drew. put the resistor on a switch so i could A/B and also have 2 modes. and seemingly all it's doing is cutting the repeats short and not actually changing the frequency response at all
