Jbanks
This debate has been summarized as box before you rock or rock before you box? I’ve gone both ways. I usually try it before boxing. But given various ground issues and wiring shorts in pots, you might not see a problem until you box it up.  You’ll end up doing both anyways. I’ve learned that 99% of my problems are in the off-board wiring issues. Surface mounted pots have helped greatly in reducing errors in wiring.
