BuddytheReow
Moderator
I've got a board I need to cannibalize for parts. What's the best way you guys have found to salvage the pots? All I've got is an iron, a pump, and some tweezers/pliers. Any pointers other than patience?
if that works. you can stay. cool idea.I am quite a noob but after struggling with unsoldering pots for an entire day, what I did was soldering a clipped resistor leg between the pot legs, covering it in solder then melting it all at once and pull the pot slowly off the board
I actually do this a similar, but opposite way, i put the vice grips on the pot(protector) and then I put a good amount of solder on the legs and then rest my iron across all 3 legs and then lift and the pot stays with the vice grips (and falls over unless secured) and the board comes with me.I would gob a little bit of solder on the leads.
Put the board in a vice grip, then lightly with tweezers or pliers (perferably with no teeth) rock it the pot back and forth while heating up the gobs of solder on the other side with the iron.
You can always clean up the solder with wick later.
That's a good idea too!!I actually do this a similar, but opposite way, i put the vice grips on the pot(protector) and then I put a good amount of solder on the legs and then rest my iron across all 3 legs and then lift and the pot stays with the vice grips (and falls over unless secured) and the board comes with me.
Found it on Reddit, I was able to desolder 3 pots that I mounted on the wrong side in my first PCB buildif that works. you can stay. cool idea.
Sounds way bette than my “tin snips and vicegrips” approachFound it on Reddit, I was able to desolder 3 pots that I mounted on the wrong side in my first PCB build
This specific model (and manufacturer) is the one to get. It’s identical to the Vampire model that is linked. Vampire tools are rebranded Engineer tools—or, if not rebrands, made in the same factory, etc.You can get one of these under a bunch of different names through prime etc:
https://www.vampiretools.com/shop/application/electrical/solder-sucker/
They are much much much better than the normal cheapie solder extractor, and short of a $400 heated vacuum situation, the best chance of getting a pot out of a PCB without lifting pads or toasting something (ime ymmv etc etc).
New username right thereFrogBro
