Big Muff Russian V8
If the green wire on lug 7 (top right corner) is ground, move it to Lug 9 (bottom right) — that'll flip when the LED is on/off.
Just to clarify, if you run one wire to the LED, where is your CLR going to be? You need it somewhere on the LED, either before (leading to the anode) or after (on the cathode).
[Edit] The voice of reason is below.
What you want is a wire coming from 9V going to the CLR, the other end of the CLR to the positive side of the LED, the negative side of the LED to that center lug of the PCB.
