mzy12
Hello!
I have a second hand boss ds-2 that I am converting to true bypass using a relay (there is no good reason for this - this is in all likelihood a complete waste of time) and I noticed that compared to the schematics, some of the diodes were not as they are 'supposed' to be. If you look at the gutshots of my DS-2 you can see that the diodes look different to other ones you can see online.
On D11, there is a red 3mm led instead of what the schematics say should be a 1ss-133 glass silicon diode (same as most of the rest of the diodes). On D9, it looks like two of the 1ss-133 diodes are soldered together in series. Then, on the D4 and D5 spots, what should be 1ss-188 germanium diodes (with a fV of about 1.0V I believe), there are instead two more red 3mm leds.
My question is, are these like a stock diode configuration? Or did the person who owned this pedal before me have a go at some mods? My board revision number is 7510952000, which matches up with the schematics I have seen online.
Thanks in advance!
Thanks in advance!
