My bandmates and I are starting to take our songs out to play live, so I had to figure out a way to transport my SCHMORG boxes.
I found that the small box I use for my vocals fit perfectly into this Anvil case- I didn't measure it or anything, it just fits by pure luck and coincidence:
Boxing my bigger SCHMORG that I use for guitar was a bit more work, but I had an idea along the way that saved me a bunch of build-time and material weight, which was re-building this old hand-me-down Samsonite suitcase:
In the beginning, the suitcase was way too deep and the shells were too flimsy to mount anything to, but I noticed that the whole pedalboard could fit inside the larger shell.
I then disassembled the smaller side of the suitcase, removing the plastic shell from the metal hoop that hinges and latches the sides together.
I traced the hoop on a scrap of plywood and cut it out with my trusty jigsaw:
After re-assembling the suitcase with the plywood bottom, I had a spare plastic shell- so I just stacked it onto the top shell which adds another layer of protection:
I added a handle to the plywood bottom so that the weight of the pedalboard doesn't strain the suitcase latches and hinges.
Inside is nothing special- just some quick mounts to hold everything in place while I'm carrying it around:
I'd like to take it apart and re-finish it to look a bit nicer like my other gear, but that's not a priority right now- I got the effects safely to the venue and back this weekend, which was the goal!
BUSTARD.Bandcamp.com
