Planning a stereo Low Tide build and wondering if there’s enough space on the corners to drill holes for standoff’s or if anyone has mounting suggestions since I won’t be panel mounting it with the pots.
When you say stereo, you mean building two Low Tides to be housed in one enclosure?
I don't have access to my build at the moment, so here is @DoubleJ's build:
As you can see, it's a tight fit in a 1590BB for a single board.
For a stereo Low Tide, your best option is to get two of the Mini PCB sets and build into a 1590XX.
Here's Digitalyeti's gutshot of his Low Tide Mini build:
I’m planning on using dual gang pots for most of the controls (except LOF & Slew) so was thinking of drilling holes in the board or otherwise mounting them to standoffs in a case large enough to hold both boards but not panel mounting them since I won’t be mounting many pots on the boards directly.
May end up being more hassle than it’s worth but only one way to find out…
