Pauleo1214
I am wondering if I used an incorrect resistor somewhere. I am building a combo build that combines the Crystal Drive and Shika Fuzz in parallel with a clean signal blend.
While the clean blend works, I get no sound from either board. I measured 9 volts going to each positive terminal of each board as well as at the diode. There is no voltage whatsoever at the transistors at each board. Can anybody spot anything wrong?
