Jeff C
New member here and also new to building pedals, as you will shortly see.  I previously built a BYOC Reverb pedal kit successfully and it sounds great.  I’ve also built from scratch a Strat, a Tele, a 59 LP, and an LP Junior.  So, I wanted a blues driver pedal and thought I’d take a whack at the Cobalt Drive from PedalPCB. The directions are not as detailed as in a kit so I’ve had some difficulty. Clearly in over my head.  I managed to procure the parts from the list (not without trial and error on my part) from Tayda.  I mistakenly bought a switch without solder lugs so after consulting a patient, helpful friend, bought a daughter board and did my best to figure out how to marry the two - having no skills whatsoever in electronics.  History major.  I have managed to assemble it but I get nothing from it except static pops when I plug it in.  Bypass doesn’t work.  No idea what I’ve done wrong but I suspect it revolves around needing to do more with the daughter board on the switch.  But what do I know?  Here’s a couple of pics (the power jack is not there but I did connect it to test).  And I haven’t installed the LED yet.  Any and all suggestions are eagerly welcomed.  You may recomemd I should just start over but I hope not….. Thank you!
