I've build the Corduroy fuzz for the 2nd time and after a succesfull build with a working brightness pot (wasn't working in the first build) I found the pedal too dark and replaced the 25k bright(ness) pot with a 50k pot.
This was tedious and hard to remove and somehow the 50k pot doesn't seem to do anything tone/brightness wise anymore. I checked if the pot worked and all connections were still intact which was the case. So looking at the 50k pot it reduces the corner frequency to 250hz or something? The advantage of the 50k pot is that it makes the pedal brighter so a working pot is not a necessity but I'm a bit flabbergasted why I keep having issues with this brightness pot?!
I build around 40 pedals with veroboard and PCBs and have always been able to fix broken parts of build mistakes. So in general I want to find out why this pot isn't working anymore and also what mod options there are related to increasing the brightness of the fuzz?
Here are some threads already discussing this:
Brian Wampler: https://www.thegearpage.net/board/i...vet-love-it-or-leave-it.1489711/post-18858881
https://forum.pedalpcb.com/threads/muddy-corduroy.1547/ with a good explanation of the different tone related options in this pedal by @Chuck D. Bones .
I would love to be able to better understand how to interpret circuit parts and specific tone (stack) related mods/options. Anywhere to read up on this (videos, online articles, books) and how to best learn and approach this?
For me I think I'll try to go back to the 25k pot (hopefully everything stays intact) and socket the caps C18 and C19 to experiment with lower values or removing C18.
Corduroy too muddy on Big settings
Is there a way to fix the muddiness of this pedal? I've checked the circuit around the 2n5089 transistor. All my values are correct. J201 is also dialed-in on the Tight side but when I switch to Big, everything is just too muddy. Is there too much bass going into this circuit? transistor...
forum.pedalpcb.com
