I owned the Original Boutique version of the pedal above in 2013 but it was way more involved.Hi!!
Anyone know how can I UV print pedals or plexiglass like the photo at home?
What do I need?View attachment 32968
Thanks all for recommendations
What kind of ink works best with linocut in your experience? I've tried linocut before, it's fun, but I've always failed to succesfully print it (granted, I've used hard lino)Screen printing is a pretty fun hobby.
Alternately you could do linocuts with medium-soft linoleum. Similar results, but a lot less expensive and a lot more labor intensive
Can’t think of brands, but not speedball— not a fan of any of their stuff. I’d suggest oil based, and you want it to be a fairly thick and stickyWhat kind of ink works best with linocut in your experience? I've tried linocut before, it's fun, but I've always failed to succesfully print it (granted, I've used hard lino)
I think a printed pedal, along with the printing matrix, would make for the ultimate boutique experience (not that I sell any of the pedals I build)
Thanks! Hopefully in a few weeks (more likely months, though) I can report some successCan’t think of brands, but not speedball— not a fan of any of their stuff. I’d suggest oil based, and you want it to be a fairly thick and sticky
The best ink is going to be based on what surface you’re printing on, and how opaque you need the ink to be. My wife is a printmaker (she has used linoleum but is not as well versed in it as in many other techniques.) in any case, I’m happy to ask her; let me know.What kind of ink works best with linocut in your experience? I've tried linocut before, it's fun, but I've always failed to succesfully print it (granted, I've used hard lino)
It's could be interesting to use labelsUV printing requires a UV printer. They range from a couple thousand dollars to up a couple hundred thousand dollars.
Screen printing is a bit more affordable, but involves more labor.
Alternatively you could print on clear adhesive labels and attach them to the back of the plexiglass or face of the pedal then cover with plexiglass.
That would be awesome, thanks a lot!The best ink is going to be based on what surface you’re printing on, and how opaque you need the ink to be. My wife is a printmaker (she has used linoleum but is not as well versed in it as in many other techniques.) in any case, I’m happy to ask her; let me know.
something like this to engrave plates or pedals with my designs? I love make pedals !!
Well, I don’t have any solid recommendations—her experience is with inks on porous surfaces; since you want to print directly onto the pedal (or it’s painted surface) that ends up being different. I can guess though, from my experiences painting aluminum, that raw aluminum would be more difficult than painted. (As an aside, to paint raw aluminum, after a good solvent wipe down, I’ve always used an etching primer. I’m not sure if these come in spray cans or not. What we mixed, (Dupont Variprime) is a 2 part system that has a shelf life of 4 days after it was mixed.)That would be awesome, thanks a lot!
Opacity is secondary, really, it's far from a main concern.
In terms of surface, I could adapt, but either raw aluminum, powder coating (not sure of the polymer, though, I buy them already coated) or spray painted (epoxy resin, I'm guessing)
Wow, that's so much more detailed than I could've asked! Thanks a lot!Well, I don’t have any solid recommendations—her experience is with inks on porous surfaces; since you want to print directly onto the pedal (or it’s painted surface) that ends up being different. I can guess though, from my experiences painting aluminum, that raw aluminum would be more difficult than painted. (As an aside, to paint raw aluminum, after a good solvent wipe down, I’ve always used an etching primer. I’m not sure if these come in spray cans or not. What we mixed, (Dupont Variprime) is a 2 part system that has a shelf life of 4 days after it was mixed.)
She did say that the two choices in inks are water and oil based, and that the water has gotten much better than it was even 10 years ago. If you live in an area that has art stores, she suggested asking in the store.
This is a bit of a guess, but I think that you will get better adhesion on a non-glossy surface. To my knowledge, powder coating should not be affected by any of the inks that you’d be able to get, at least from a non-industrial supplier.
A thousand years later, I can report some partial success in my my first attempt!As I said earlier, hopefully I can report some success in the near future
