Here's the stock schematic for mine, it's Made in Taiwan. Has the M5223AL SIP dual opamp. Note the typo on the schematic: C7 is actually 100pF.
C2 and C3 choke off the bass end of the spectrum, so we'll make those bigger. Change C2 to 2.2μF. I used tantalum of course. This pedal is full of aluminum electrolytics, so those are ok to use for C2 if that's all you have. Change C3 to 1μF film. That's really all it takes to get a large dose of bass frequencies into the circuit.
C8 limits the low-freq response at high DISTORTION settings. You can make that larger, but unless you're running with DISTORTION wide open, it's not necessary to change it. Lotta people increase C9, I didn't on mine.
I retuned the TONE control, completely optional, by raising C11 to 47nF and reducing R16 to 3.9K. No more midrange notch.
I did like Keeley and replaced D5 with a 3mm red LED. If you want the "seeing eye," then drill a 3mm hole thru the O in TONE and mount it there.
There are tons of other mods, most of which I think are bogus. One popular mod is changing the biasing & gain on Q2. I did my own version of that. I increased R9 to 470Ω, then I added a SPDT on-off-on switch that connected either a 2.2μF, 22μF or nothing in parallel with R9. With nothing in parallel with R9, Q2's gain is reduced, making it run cleaner and flattens the freq response a bit. Adding the 2.2μF cap increases the gain in the upper mids and treble range but leaves a tight bottom end. Connecting the 22μF cap boosts the gain at all frequencies for nice fat tone. If all you want is the ultra fat tone, then leave Q2 alone.
The LEVEL control should really be A-taper, not B-taper. As soon as I obtain a 9mm A100K knurled pot, I'll change mine out.
I did not do any of the "boutique" mods like replacing the two disk ceramic caps with silver-mica, or replacing all of the film caps with WIMA. IMO, it's "good enough."
