rundgrenrules
So I have the Duo-Phase all put together according to the "Two Inputs / Two Outputs" scheme on page 6 of the build doc. Based on what I've read and watched, I should be able to plug into the input on the right side of the pedal (looking at front of pedal" and from the output on the left side and as long as I dont have anything else plugged in I should be getting signal and the phasers wired in series.
The problem is, when I plug it in this way, I can only hear a very very small amount of signal coming through. Enough to tell it is phasing, but obviously not a correct amount of signal, like it is 95% shunted. I cant see where I have deviated from the wiring scheme in the build docs. Can anybody see if I did something obviously wrong with the jacks?
The two sides operate as expected when plugged into separately and tested.
Thanks anyone and everyone for any help!
