Duocast Low Cut Not Working
I'm really digging the DuoCast build I finished up today.
Only problem is that the Low Cut knob does nothing.
Everything else works.
I've built the Simulcast as well so I expected the Low cut to function in a similar way to that.
No change across the entire sweep.
The lug connections are solid.
Any ideas?
Thanks!
Pictures? There’s only 3 components attached to it so it’s gotta be something silly. Measure the resistance across your pot as you turn it to make sure it’s working.
