innerlight
Hello all!
I am once again asking for some guidance on an almost functional build (pics attached). This one came together cleanly and I was really confident it’d just work .
I’ve reflowed all solder points and double checked components. I assume the dot on the OC71 is meant to match with the square on the Pcb?
Anyway, LEDs light up, pots make sounds but no signal passes in low or high modes when engaged. Signal passes when not engaged. Curiously, when I switch between 9 and 27v modes I get a pop and a split second of signal.
Do I audio probe next? Please guide me oh community.
