El Sol - Gating Issue
ckendall924
I know this has been posted previously and resolved, but I'm having this same issue and cannot resolve it using any of the suggestions on the previous post.
I get clean bypass. LED turns on, great big Acapulco Gold sound when I dig in. But the sustain dies abruptly with a fuzzy gated sound. The signal even dies completely and back on in a sort of swelling sound as a chord is allowed to ring out. (It's kinda cool, but also not the intended sound with this circuit.)
I've posted some pics below. (Just one thing to note, the pic of the back of my pcb should've been updated. I reflowed all of my solder joints as a good measure. Also, I have 2 sets of the JRC386 chips. I swapped out the IC's to see if that would do the trick. No success.)
Any ideas would be helpful.
A LM386-3 helped here:
I assume you checked the values for your components. I can't read your resistor stripes or cap values.
I don't see any solder on the component side of the 4n7 cap which is fine but maybe something to check if your reflow didn't fix it.
Hard to tell, but some of the solder joints look like they might be cold joints - i.e., the solder doesn't flow smoothly onto both the pads and wires, but instead have some dark pits in them. So maybe there's an oxide layer in between. I've highlighted a few questionable joints here (compare them to the others under magnification):
What solder do you use? I'd stick with a top brand like Weller or Kester, cheap solder isn't worth the pain of debugging bad joints.
And when you reflow the joints, do you touch the joint just with the soldering iron or also with a little touch of new solder (so flux is present, which helps solder flow better and clean up the connection). I recommend the latter.
Another thing to try is to check the signal path and find where the fuzz occurs. You might work backwards from the output until the signal looks clean. You can do this with an oscilloscope, if you or a friend are fortunate to have one.
Just my 2 cents, I wish you luck in getting it fixed.
Appreciate that… I’ll look at them again. I did go back over them and flowed new solder after that photo was taken, but I can triple check them.
And yes, I’m using Weller.
Wish I had an oscilloscope!
I did get some LM386-N3 chips, so I can give that a whirl also.
Something is definitely not right with my pcb... I went over the values of the components and wasn't getting a read on R1, which is a 1M resistor. I've decided to replace that resistor, but I'm having a terrible time getting the solder out of one through hole.
In the interim, I decided to breadboard this circuit and see if I got a different sound. I was able to get this thing working beautifully on the breadboard!
It's making me think of just building this circuit and power section on a perf board and putting it in a pedal enclosure. (Maybe even do one of the mods that exist out there and include a separate tone control?)
I did a PTP version, it's over in build reports. Easy peasy.
That’s awesome!
Yeah, the P2P stuff is really cool, but above my level right now. I think the perf board will be the PERF-ect compromise 😃 (please forget that I said that 😕)
Yup, agree with comradehoser.
@ckendall924 — YOU CAN DO IT!
A 1,000 mile journey begins with one step.
The first step is easy, just decide to DO IT!
