KR Sound
Whoa! How does that site work? Is it pretty accurate?
Edit- all done manually he says.
“When I'm satisfied with the dry, unaffected loop, I reamp it with the Radial Engineering Pro RMP Reamp* and record the whole loop with different settings on each pedal.
For each setting you see in the demos, I recorded the whole loop with the pedal set to that setting. The loop has to be recorded for every single setting, which amounts to about 30 audio files per demo”
