Does anyone know how to wire the speed 3pdt switch without the breakout board? I believe I fried my footswitch and the board all in one stupid sitting....
You could continuity check your 3PDT board to see which pads connect to which 3PDT lugs
You can see the where the top 2 outer lugs connect here so check the rest and solder direct from the 3PDT lugs to the corresponding pads on the main board
