SOLVED Fornicus Overdrive Threshold issue
effectism
i recently finished this project the Fornitus Overdrive but i have an issue
seems to work the volume , hi-cut and Drive i hear the differences when turn the potentiometers but i did not hear any differences while i turn the Threshold potentiometer (only i see some changes at led) also no hear any differences when i turn on or off the Sag switch and the Weight switch (no hearing heavy or light at my sound).
you have any idea about this problem
thanks a lot
*upload an image from the pcb
I’m guessing it has to do with the position of the trimmer. I’m not 100% why it’s here but It looks like it either dumps the IC before it to ground or passes it to the threshold pot. I’m guessing you adjust it by ear try it in the middle and go from there.
