It's a 6-Knob Type 1, you don't need to have it custom-drilled.The holes will need to be custom drilled and then i goto find a way to make it all fit inside the enclosure while adding the extra 2 knobs somehow without loosing the Jcm 800 logo.
The only reason I need it to be custom drilled is so that it can fit into my design, otherwise it would fit perfectly into that enclosure you mentioned.It's a 6-Knob Type 1, you don't need to have it custom-drilled.
Hmm i wonder if i could use these kind of potentiometers and if its posible to even find them.
Sweeet thanks!Alpha-Pots 9mm
Alpha-Pots 9mm: Alpha Potentiometer 9mm 2k lin - Alpha Pot 9mm 100k log dual concentric - Alpha Pot 9mm 10k log dual concentric - Alpha Pot 9mm 500k lin duawww.musikding.de
OK, I get you. For the lower middle knob, you could use a D-shaft pot and these knobs, they are really small. Or use these on both the pots you want to relocate if you want to minimize footprint and have a mirrored design.The only reason I need it to be custom drilled is so that it can fit into my design, otherwise it would fit perfectly into that enclosure you mentioned.
Awesome thanks for the info!!OK, I get you. For the lower middle knob, you could use a D-shaft pot and these knobs, they are really small. Or use these on both the pots you want to relocate if you want to minimize footprint and have a mirrored design.
You can also find the 9mm pots at Tayda (if you're doing your UV printing there, might as well...)
Thanks!!For concentric 9mm pots (not dual-gang), and black knobs to fit, I sourced them at Small Bear.
Ohhh, now they come in silver, too!
The middle two pots are Mid and Presence, so you could probably set those two internally to keep it a four-knob. I’d personally probably just hardwire the mids knob at 10 since you get a pretty flat response with treble and bass all the way down then, and then make the presence an internal trimmer to adjust to whatever rig you’re using and then leave alone.Has anyone built the m-800 board before? This one seems like it will be a tricky build for me to pull off lol. The holes will need to be custom drilled and then i goto find a way to make it all fit inside the enclosure while adding the extra 2 knobs somehow without loosing the Jcm 800 logo. Its going to be a challenge but where theres a will theres a way
Thanks for the input!!The middle two pots are Mid and Presence, so you could probably set those two internally to keep it a four-knob. I’d personally probably just hardwire the mids knob at 10 since you get a pretty flat response with treble and bass all the way down then, and then make the presence an internal trimmer to adjust to whatever rig you’re using and then leave alone.
Nice!!You could always revamp your look
The Marshall Knobs may fit if you prefer those:
Your quite welcome to use this Mockup pictured above, Here is my Original Build:Nice!!
Awesome Thanks for Sharing!!Your quite welcome to use this Mockup pictured above, Here is my Original Build:
https://forum.pedalpcb.com/threads/m800-overdrive.935/
