Are you saying there will be more build docs?To be fair, there are a couple things I like much better in KiCad compared to DipTrace.
The project management is one. I love how the schematic/PCB layout gets grouped into a folder and is displayed in a collapsible tree.
Also, although I've not set it up or used it yet, the BOM export presets looks like a feature I will absolutely love.
Being able to export a CSV with one set of fields for creating the build doc parts list, then quickly switch to another preset to export an itemized pick list seems like a dream.
The schematic mangling is one, the other is moving components on the PCB layout. Just take the damn trace with the component!
No need for a plugin on the layout side of things. You can move the trace with the component, just use drag instead of grab. On Mac, you highlight a component, type "d" and move at your leisure. As far as mangled schematics with traces, are you open to moving the component and reattaching nets? If yes, just move it (highlight symbol type "m") instead of grabbing it (highlight symbol and type "g").I wonder if this is something that could be changed with the plugin system?
I haven't spent a LOT of time with BOM exports yet but as long as far as I can tell, KiCad is fundamentally a "grouped" component BOM export. It likes to group components based on value in BOM exports. R1, R2, R13 = 10K and so on. This becomes somewhat problematic when you're working with potentiometers that share the same value unless using a plugin to distinguish and export other fields in the BOM, like KiBOM.the BOM export presets looks like a feature I will absolutely love
You use it for work or something?The Affinity acquisition has me spooked... Losing access to Affinity (by choice or design) would be a pretty big inconvenience, but I could manage... Losing access to DipTrace unexpectedly would be devastating.
I'm pretty sure there's no way to prevent that given the example you've shown. Is there a reason that you couldn't just grab the block of components and drag them AWAY from the rest of your components to make edits rather than dropping them on top of others?If I do this same thing in KiCad it would automatically connect any of the lines that intersect when I drop the selected components.
F-it, sell the kidney, you only need one to survive.That must be a KiCad 8 feature. Unfortunately, I’m stuck at 7.X unless I want to sell a kidney for a new MacBook Pro.
It is. Have you *tried* running 8.x?That must be a KiCad 8 feature. Unfortunately, I’m stuck at 7.X unless I want to sell a kidney for a new MacBook Pro.
I have not. I guess I could try, I just figured it’d have some type of OS authentication that would fail on Big Sur.It is. Have you *tried* running 8.x?
Most of the Mac support stuff I've seen from them is they only *officially* support the last 2-3 os releases, but only due to the OS verification team being 1 person and newer releases way work on older OSs just fine.
