benny_profane
This thing is incredible. It's an extremely versatile modulation circuit capable of delivering hollow pipe and jet engine flanger sounds as well as subtler flanger movement. Beyond flanger, lush chorus, vibrato, percussive tremolo, and a pseudo-phaser can be dialed in. Removing the LFO allows the pedal to be used as a really interesting notch filter. In short, a knob turner's dream. Highly recommend this build for anyone considering it.
The circuit board is densely packed, but well-designed and easy to populate. The Lectric crew did a great job here! There's no wasted space on the board (or within the 1590BB enclosure). The calibration process rather involved (even by BBD standards), and range parameters are a bit too sensitive for the single turn resolution trimmers—a multi-turn trimmer would make calibration easier—but it's doable with the 3362p trimmers with patience.
The interaction between the MANUAL / RANGE / SPEED controls is extremely interesting. The THRESHOLD control helps deal with some of the noise inherent to the circuit while adding dynamics to the response.
When I was picking out the color palette, this combination reminded me of some of @Bio77's builds. I took a cue from some of his builds and used a similar typeface. @thewintersoldier provided guidance with the board mounting. (Thanks again for the help guys!) I'm not sure if I'm set on the knobs.
Check it.
Check it.
