A AngelRiot New member Sep 5, 2020 #1 I just built the martian fuzz and when engaged it works perfectly but the volume is just super low, is this by design?
Z zgrav Well-known member Sep 5, 2020 #2 Probably not by design. If everything is working on the pedal aside from the volute drop you should carefully check all of the solder spots on the PCB. Odds are good you have at least one spot where you are not getting great contact. Upvote 0 Downvote
Nostradoomus Well-known member Sep 6, 2020 #3 Confirm your resistor values too, that’s a pretty common issue! Upvote 0 Downvote
