Not sure if this is the correct thread for this...
I am in the middle of the Thumb Sucker and drilled yesterday and noticed too late that with a Bezel for the stomp LED, the Bezel comes high enough to touch the PCB and then the hole is est 4-5 mm too close to the stomp.
I will take out the plastic isolation thingy in the Bezel to get some maneuver room, and shrink tube the LED leads to keep it out of "harm's way". And solder the wires from PCB to stomp(pcb) on the top side so that their wire shielding plastic keeps them away from the LED.
It's a workaround, but if you are going through build docs at some point you could adjust or make a comment. A smaller and shorter plastic bezel might make it a non issue...
Cheers
