Wondering about those too....I'm guessing we wont be seeing the schematics for the King’s Hand and Lone King overdrives?
+1Wondering about those too....
I see the Lone King build docs are now posted. While working on my graphics and overlaying the drill template, seems that the Voice switch is off. On the template, the switch is centered with all 4 knobs. On the PCB, it's off center, towards the top. Am I not looking at the layout correctly?
I think your pots are not oriented correctly. If you arrange them so the shaft are above the holes in the board, then the swtich will be in the middle.I see the Lone King build docs are now posted. While working on my graphics and overlaying the drill template, seems that the Voice switch is off. On the template, the switch is centered with all 4 knobs. On the PCB, it's off center, towards the top. Am I not looking at the layout correctly?
Second question - I also have the Kings Hand PCB and was planning on putting them both in the same enclosure. Would sharing the power supply and running the out of the Lone King into the Input of the Kings Hand cause any issues? Neither of these should have too much of a current draw, both running same voltage and one into the other with true bypass, shouldn't be a problem combining them into the same box right?
A lot of times people think the drill template isn't aligned correctly because looking at the PCB the toggle switch isn't in line with the pots (because of the 16mm vertical offset of the pot shaft).Not sure I'm following your suggestion.
Not sure I'm following your suggestion. Lining the pots with shaft over the hole still leaves the center lug of the switch (equiv of being straight up in the center position) spaced too far up.
I'll get it posted as quick as possible.No trouble at all, thank you for updating it so quickly! Are there any updates as to when the Kings Hand build docs will be available? The intention is to put them into the same enclosure. Or are there plans to combine these two into a single PCB at some point? If so, i'll build Hand / Lone separately.
And terrarium!!Another big PPCB fan here eagerly awaiting the King's Hand build docs?
And terrarium!!![]()
