Paragon/KOT dual jacks?
beachbum
I'm interested in getting the Paragon PCB, is it possible to make separate inputs and outputs for each side that normalize in series when only one is connected? I know this is an option on the real KOT. Also is it possible to fit the external switch on the outside without too much trouble? Wiring the pedals up is my least favorite part and the one I tend to mess up the most.
I've actually been free to order a real King of Tone for the last 18 months or so. But with outside switches and the 4 jack option, I was looking at close to $400. Plus the Canuck xchange rate - no thanks!
That's perfect thanks. Do you know if it's easy to get the Dip switch working on the outside with a 3 position switch?
I've not done it myself, but enough builds seem to have them that it's definitely doable. I have learned a LOT by searching this forum, it will have definitely been discussed. Give it a go.
