WheatAndBarley
Not sure if anyone has posted this yet so thought it might be good to get the word out. I'll also say up front I don't think this will affect anyone doing PedalPCB builds.
Tayda seems to have switched up their 125b enclosures, dunno if its a new supplier or what. I don't believe the dimensions of the face changed but the inside dimensions have changed a bit. The inside distance between the screw posts on each edge are about 2mm shorter.
This is a bit of a problem for me because I use a PCB with the jacks mounted on it and suddenly these assemblies don't fit. Been using these for hundreds of pedals over the last year and I had almost 40 orders to fill at the time so it was a huge stressor to have to deal with. I ended up having to trim the outside corners of the jacks down in order to fit, which I guess I'll have to do from now on unless I start getting them from a different place or change up my i/o boards somehow.
But again this is probably not going to be an issue for most people.
