Geez, I'm glad they gave you a Bonnet latch so you can service the Engine!When I had to replace the fuel pumps on my Jag, it was easier to cut an access hole than to remove the fuel tank.
She's all back together now and running smooth.
We have clear skies for the first time in about 5 days here in Toronto. Enjoy!Spending the weekend at the in-laws’ house. The haze is from the Canadian fires- pretty wild.
I wish i read this earlier! I did have an engineers hammer trust that little hammer did NOT help at all! The skill saw is a great idea and am going to buy one right away. Like you said the angle grinder does not cut deep enough. I had to cut as far as the angle grinder would let me then pound away with the engineers hammer to break up the concrete. Used a shop vac to remove material and did it all over again till i got all the way thru the concrete and to the other side. Im going to be sore in the amMaybe pick up an Engineer's hammer from Harbor Freight. It's like mini-sledge hammer. If you have a skill saw, get a concrete blade for that because it will cut deeper than the one on your angle-grinder. When I had to cut thru my slab floor to repair a busted sewer pipe, I had my son there pouring water on the cutting area with one hand and holding a shop vac hose with the other. We both wore masks too.
The assholes who ran underground wiring to the barn on my property buried EMT, which is a no-no because it rusts right thru. Happened before I lived there, but I was the one who had to clean up the mess. Whether you get a permit or not, make sure the work is done to code.
Damn. The only job I did that sucked more than busting through concrete was driving fence posts for a horse paddock in Texas. In July. On limestone. My hands looked like raw hamburger by the end of thatGetting a new shed installed to expand my work place. Need to run power from the house to the shed but we have to cross this concrete walkway in order to get there. First time working with concrete this sucks
