Relay Board doesn't match docs
mstrat
I just received a relay board that differs from what's in this build doc: https://docs.pedalpcb.com/project/PedalPCB-IntelligentRelayBypass.pdf
Some example differences:
* It has a 100K below the attiny, where the build doc shows C2.
* It has a 100n where build doc shows R2
* It has "CTRL" pads on the lower right and left
Please advise. Thanks!
UPDATE: If anyone comes across this with the same question.... It's an updated board. Follow the silkscreen. Omit the 100k. Ignore the ctrl pads.
Thanks for the info, I was just wondering the same thing. What is the purpose of the 100k resistor and the ctrl pads? Why is it okay to omit the 100k resistor?
Also FYI if you're looking at the schematic in the published build doc, the 47k pull up has been removed.
