My party line is at: Guitar 7/16 42 50.I think you’re right. In that case I’d like to phone a friend. What’s your number?
I should have something together for you this weekend.I am gonna need a video tutorial, I’m a visual learner.
its such a tempting option but can turn to nuclear levels of frustration in a heartbeat.I score each side a bunch with a blade, then I pull it off with pliers. I learned real quick that ribbon cable isn’t easy…
I have both and its still not all that easy...aaaand a quick search turns up solid core ribbon cable and a set of those 'auto adjusting wire strippers' that can do flat/ribbon cable.
hmmmm
I only use pre-cut pre-stripped pre-tinned ribbon cables. You can get them at Stompboxparts and BLMS, as well as other places I'm sure.
Stompboxparts has them in 1" lengths, I usually get mine from there (not affiliated, I promise)I use the ones from LMS. I usually cut them in half, since they are usually a bit overkill. I rarely need more than an inch, more or less...
I tried that and only succeeded once, then ruined a couple of strips and gave upI score each side a bunch with a blade, then I pull it off with pliers. I learned real quick that ribbon cable isn’t easy…
Yes! Which brand is this?y'all need some automatic wire strippers to make your life easier for ribbon wire
No clue, I just pulled a random one from google images. I bought some generic one on amazon thats served me wellYes! Which brand is this?
This is the one I use. Love it. But it does not work well on Ribbon cable. I don’t see the point of ribbon cable personally. Just seems a lot easier to work with Buss wire.
