Looks awesome, loved the stamped enclosure. For what it is worth, I have read that many of the Catalinbread designs are noisy. It could be inherent to the circuit. I don't see any issues with your off-board wiring that would create an issue. You could try shielded wiring, not sure if it would help.
Very cool look! My DLS Mk 3 (Covert) is very quiet. If you have hum, short out the input and see if it goes away. These pedals have a shit-ton of gain, so even a little bit of hum or noise coming in gets magnified. There is no "clean" setting, unless you back off on the guitar volume.
Thanks again! I tried wiring along the sidewalls and same noise. Maybe I will change transistors, but I like some configurations of the pedal right now. Not so bad ....I used NOS MPF4393. My source has since dried up. Any N-channel JFET with Vp around -2V will work. Your build looks good. My only suggestions for dealing with oscillation is to route the input and output wires away from the board, along the sidewalls of the box and make sure the pots and jacks make good metal-to-metal contact with the box. Something to consider with Boutique pedals: it's possible that some combinations of control settings will cause problems. Look online for demos of this pedal and see if anyone turns the GAIN up all the way in Stoner Mode.
Can you describe the noise or upload a sound clip?
I have just finished one and used PN4393 transistors, I don't find mine overly noisy. I mostly use lower gain settings but even if I crank it up (and boy it does have gobs of gain...) it seems comparable to other high gain pedals noise wise. Maybe there's something else on yours...? I will check later again on very extreme gain settings and will let you know if I find anything like you describe.
Original catalinbread pedal using carbon film resistors and carbon composition resistors. If you make your pedal using metal film resistors,, you will be disappoint your pedal sound.
Look picture of PCB and change all resistors like original pedal.Catalinbread - SFT REV 2
Someone share me the SFT REV 2 for the week, so I take pictures and get values of capacitors and pots, maybe it can help for helping debugging the previous tracing. This is pictures: https://www.dropbox.com/sc/p76h70dy0ch3wkn/AACdRnEuL0o7n_CG8ttR24Bxa Ifreestompboxes.org
Thank you! I thought the carbon ones are noisy than metal resistors, although I have enough insecurity desoldering, I think I'm going to try to change them.
Any advice to desolder?
What´s the tonal differences between composition and film?
Maybe I will replace resistors carefully.. . .
One thing i have noticed is when you remove the lid and leave the box without closing the background noise increases more than other pedals.
Faraday cage - Wikipedia
en.m.wikipedia.org
