I am about to build this particular circuit but notice the schematic calls for 3 capacitors which says "BP" yet clearly has the symbols for polarized caps. Which type is preferred? Can BP's be used and if so, would there be any advantage or disadvantages? thanks in advance.
BP or bipolar, non polarized wouldn't make much difference looks like you could use either as long as you get the polarity correct If you use polarized caps, there wouldn't be any advantage using either type apart from cost
BP question. So can I use a polarized cap as long as I have the polarity correct. The positive side goes with the positive and negative with negative? Sorry I build a lot my pedals with crayon.
