vigilante398
Authorized Vendor
Well I have good news and bad news about this one. The good news is I finally got a design that works perfectly. It sounds exactly the way it's supposed to, the voltage is holding right where it's supposed to be, and it looks great. The bad news is apparently it doesn't fit in all 125B enclosures. When I designed the board I used the Hammond measurements as a size reference, and I should have 2.44" between the ridge on the bottom plate. The board was designed to be 2.36" wide, which I figured would be enough. But I put it in a Tayda 125B, which I've noticed have increased their wall thickness from 2mm to 3mm. This extra 1mm on each side is enough to make the board hit the ridge on the bottom plate, so you can't close the pedal up. I hate to throw out these boards (this is the 4th revision of the design), so I may just get a big order of boxes from another supplier that would allow the boards to fit and offer those pre-milled with the boards.
So anyway, Space Heater. I was asked a couple years ago to design a super simple tube preamp with just gain and level controls for people that just wanted simple tube warmth with a little bit of grit but with no tonestack. Space Heater is what I came up with. It's a great place to start if you're looking to get into tube circuits due to its simplicity, and it's the basis of what I ended up with in this thread.
It's supposed to fit in a 125B enclosure with top-mounted jacks. Like my Black Eye design it uses a separate footswitch board and a ribbon cable between the two for easy wiring.
![IMG20220721001957.jpg IMG20220721001957.jpg](https://forum.pedalpcb.com/data/attachments/29/29561-8767eec6a1c2e9569c8a95d9a704718b.jpg)
![IMG20220721002003.jpg IMG20220721002003.jpg](https://forum.pedalpcb.com/data/attachments/29/29562-724948a7d011c79b543c86ef39720038.jpg)
