So, you DON’T have to let it linger.
Yes, there should be a line on the PCB that shows which way the heatsink goes.Just finishing wiring up my SH. Is there a proper orientation required for the IRF740? I don't see any indication on the PCB.
I had the same question, didn't see the line, I just looked at @vigilante398's build pictures and copied the orientation......makes me look smart but I'm just a monkey....hahahaYou mean the line that's on the opposite side of where I have it installed?????
How long has the retail Black Eye II been available?Yes, there should be a line on the PCB that shows which way the heatsink goes.
It's a new release for November 2022, so it's been available as a pre-order custom build for about 2 weeks.How long has the retail Black Eye II been available?
Can we see a picture of the build? What kind of tube do you have in it?Got things rectified (amplifier joke??) with the IRF740 and when the GAIN is turned up a little over half way I get a "warble" (sounds like R2D2 from Star Wars) followed by a high pitched screeching the rest of the way up. Its roughly a high frequency multiple of 60 hz cause it is enharmonic with the B on my guitar. Tried two different JJ tubes. No problems on the LEVEL. Got any recommendations?
You're not crazy, you have the newer version of the PCB which has the LED mounted under the tube socket. Updating the build doc with current pics has been on my to-do list for a while now. It will get done eventually.I was going to use an ohm meter to see if any of the solder joints bridged. Some "register", but that may be due to their placement in the circuit so I started to note them on a photo of the PCB from the BOM only to notice that the BOM layout appears different than the PCB I have. VIG, am I crazy?? (don't answer that). . . .
I would check your Resistor values are Correct?I was going to use an ohm meter to see if any of the solder joints bridged. Some "register", but that may be due to their placement in the circuit so I started to note them on a photo of the PCB from the BOM only to notice that the BOM layout appears different than the PCB I have. VIG, am I crazy?? (don't answer that). . . .
The solder pads are pretty tight on this one. You're solder joint game needs to be super on point, just enough solder to get a good bond but not too much or you'll get a bridge, it took me 2 boards to get my first working pedal. The the spots Phil has pointed out in red are definitely suspect.I would check your Resistor values are Correct?
Here is a Resistor Calculator, Click on Bands for 5 colours.:
Check your Solder Joints, this one doesn't look right circled in Red:
Resistor Calculator
Resistor Calculator is an App developed by CherryJourney to help the user find the value of a resistor.resistor.cherryjourney.pt
These look Suspect, the one next to Out looks Iffy???
Been there done that.....twice hahahahaGonna just start over. The cost of the PCB and the light component count make it less of a hassle. Thx all!!
