NeedMorePedals
Where can I find the BTDR-2H (long) IC called for in the BOM? This is for the IC2 component on the pcb. I checked small bear and tayda, to no avail. All I can seem to find are SMD reverb IC's. Thank you.
Thank you Betty. Where would I find the short brick? Found a medium...The brick mounts to the back side of the pcb with the potentiometers. I personally prefer the Short Decay brick in this circuit. The Belton brick has built in modulation that is exacerbated by the longer decay times. I find the modulation less desirable. Also, the Short Decay brick is more spring reverb and less ambient chamber sounding. If that's your thing.
Thank you so much for your assistance! I may try all three. This is my 20th or so build, and my first modulation effect. I learned a lot from you all!I get mine at Small Bear. Very reputable source.![]()
Belton BTDR-2H Reverb Modules
Guitar pedals, parts and electronicssmallbear-electronics.mybigcommerce.com
It’s super confusing isn’t it? I don’t understand it either.Really, it should just rebrand as one coherent company with a matching URL.
