My first thought reading that was: "Well, that's the jorts of closing an enclosure."I only use two screws on my enclosures. Is usually find the hole that works best, and then try and work with whatever the opposite diagonal hole is like…
Just don't force these, they will snap!
I put the bit on my hand drill
What's the worst that could happen?
I use one of theseFYI - The worst that could happen is you bottom the tap into the bottom of the hole too hard using your drill, the tap snaps off flush, and you have a piece of hardened steel permanently lodged in your screw hole.
I'd always try running the tap into the hole with just your fingers first. That may be enough to get a little bit of paint out on it's own. If there's too much resistance, I'd switch to a tap wrench, but a little adjustable wrench or pliers could also get the job done.
Bottoming tap would reduce risk, as would the use of cutting fluid (this is aluminum so wd40 is often better than fancy expensive fluidFYI - The worst that could happen is you bottom the tap into the bottom of the hole too hard using your drill, the tap snaps off flush, and you have a piece of hardened steel permanently lodged in your screw hole.
A bottoming tap will cut threads all the way to the bottom of a hole, but isn't any less likely to snap if you ram it into the bottom of a hole with a drill. Might actually be more likely to snap if the original hole wasn't tapped with a bottoming tap, as your bottoming tap will be cutting new threads toward the bottom instead of just cleaning the junk out. I think the safest option is not to get anywhere near the bottom of the hole, as the overspray is likely to all be in the first couple threads anyway.Bottoming tap would reduce risk, as would the use of cutting fluid (this is aluminum so wd40 is often better than fancy expensive fluid
There are special extractors for broken taps, however not likely to be found for smaller ones like this. So what did my machinist friend tell me to do when I broke off #4 or #6 taps? Hit the broken tap with a center punch (PLEASE WEAR SAFETY GLASSES!!) and it will likely shatter… then pick out the pieces with a machinists scribe. Since taps are extremely hard, it makes them very brittle (why they break easily), so smacking them with a center punch ( the kind you use a hammer with- not the auto type) takes advantage of that to make them crumble and easy to pick out.
You can buy the handle separately. https://www.amazon.com/dp/B00004YOB0?psc=1&ref=ppx_yo2ov_dt_b_product_details@spi - where'd ya find that? All I'm seeing are bits, but I wanna get a manual one like that.
I got this https://www.amazon.com/dp/B01EOD217S?ref=ppx_yo2ov_dt_b_product_details&th=1 and this https://www.amazon.com/dp/B00004YOB0?psc=1&ref=ppx_yo2ov_dt_b_product_details@spi - where'd ya find that? All I'm seeing are bits, but I wanna get a manual one like that.
