@PedalPCB stated in another thread that B1M will work as well and is easier to grab or wasThe Low Tide needs an A1M pot and @StompBoxParts has good stock of ‘em
16mm Dual Gang Potentiometer - Short PCB Leg
Top Quality Parts for Guitar Effects Pedals and DIY Music Devices. Knobs, Pots, Switches, Kits, LEDs, Enclosures, Jacks, Wire, Resistors, Capacitors, Semiconductorsstompboxparts.com
yeah at the time A1M dual was hard to get (I had to wait weeks for Smallbear to restock for my first build) so B1M dual was the only option, but the BoM and OG pedal are A1M and SBP's got good stock these days, so unless you've gotta order 100% of your parts from Tayda, getting the proper A1M is the way to go. I find the slew control already pretty touchy with an A1M (unless you want all the way squared or all the way smooth), I'd imagine a B1M would make the sweet spots in the middle even harder to dial in.@PedalPCB stated in another thread that B1M will work as well and is easier to grab or was
until smallbear reopens (and has the pot and the delay chip) I'm not a 100% on how you get this project down to two vendors ... I just did my shopping and it included tayda, guitarpcb, and stompboxparts (four if you count pedalpcb for the board, pot condom, and faceplate). some projects are just expensive.yeah at the time A1M dual was hard to get (I had to wait weeks for Smallbear to restock for my first build) so B1M dual was the only option, but the BoM and OG pedal are A1M and SBP's got good stock these days, so unless you've gotta order 100% of your parts from Tayda, getting the proper A1M is the way to go. I find the slew control already pretty touchy with an A1M (unless you want all the way squared or all the way smooth), I'd imagine a B1M would make the sweet spots in the middle even harder to dial in.
I'm not bummed at all! I learned a lot last year and got a lot of playing in as well. I'll leave the scoreboard to the swinging bats.That's a bummer cause you didn't complete a lot of builds last year. Ya'll dropped Fig's batting average
perfect ... gives me enough time to be tired of the low tide by thenLectric-fx is dropping a ce-1 soon. That's the chorus we all deserve
Benson needs this pot. I should have ordered one for mine. Will have to wait a while now.FYI: B1M dual gain pots are out of stock... for all the low tide lovers
Doesn't it need a dual gang pot?2M OHM Linear Taper Potentiometer Solder Lugs Round Shaft Dia: 6.35mm
ALPHA - Get It Fast - Same Day Shippingwww.taydaelectronics.com
Either a dual-gang 1M or a single-gang 2MDoesn't it need a dual gang pot?
