Tayda shopping cart for The Pharmacist?
innerlight
Hello all!
This is my first post here, so if this is an insane request please let me know.
I'm about to buy my first PCB from here, and I'm wondering if anyone could help me out by sharing their Tayda shopping cart for the Pharmacist build?
Some of the components get a little confusing.
I dont have a cache of parts here so ill need em all!
Thank you!
Christian
Hello all!
I'm about to buy my first PCB from here, and I'm wondering if anyone could help me out by sharing their mouser shopping cart for the Pharmacist build?
Thank you!
Christian
You might have a better chance of success if you build a somewhat simpler circuit. Won't have to worry about so many components that you have to keep track of.
Hi,
I think I can help you with that.
Do you plan to build additional pedals? If so, it doesn’t make sense to buy resistors and capacitors individually unless they are uncommon, so you would want to buy common-value assortments.
Hi,
Thanks SO VERY MUCH Fig!
I was planning on buying larger quantities of the more common caps and resistors.
Perfect. Have you built kits or other circuits previously?
If you’ve already got some passive assortments chosen, let me know where you’re shopping and I’ll see what they have. Whatever they’re short on, I probably have. ;)
Yeh Ive built quite a few, but only full kits. So this would be my first time doing the enclosure drilling and buying the components!
Okay, I’ve got a preliminary shopping list. Do you have any resistor or film cap assortments in mind? Knowing what values are missing from those will tell me which ones to include in your goodie bag. I’ve got the low-profile electrolytics, the 2N2222As, 2N5457s, A25K pot, trimmers (Tayda only stocks the breadboard type), and will fill in any blanks your assortments don’t cover.
I was able to find everything on the Pharmacist BOM, except the weird valued resistors, 2N5457, A25K pot, the trimmers, plus the 1U capacitor. Happy to get the 2N2222As from you also!
I don't feel confident enough to select the assortment, i am open to suggestions. I could just buy a bunch of each resistor and capacitor needed for this build from tayda to get me on my way. And grab all those mentioned above from you.
Did you mind the height and voltage requirements on the other capacitors? I have a spare resistor sample book I can send you. It has a few of a lot of values. I keep one handy for oddballs, but they also make a great starter assortment. I use them for smd stuff as well. Send me your address in a DM and I'll gather this together so you can get to building!
Here's some shots of the little stuff...
Where can I get my hands on one of those?!?
