Brett
One more thing...I'm brand new to illustrator and trying to prep some art for a print. It's I think a pretty simple layout but I'm not sure how to do some of the final steps. I have a bunch of pen strokes that I applied brushes to that are overlapping and I'm not sure if I need to "flatten" them down to make sure that they print with the right transparency/opacity? I also have to knock out a section of dark "ink" to let the white text show through so I just made a copy of the white text (using white as the fill instead of the Roland swatch) and put it in the color layer. I converted all the text to paths so there would be no issue with fonts but other than that I left all the objects and paths as I created them in Illustrator.
I wouldn't mind just sending it and trying out the print, but 10 days is a long time to trouble shoot some art. I exported a PDF of the artwork and then converted that into a JPEG to post here and it looks like I expected it too but I'm a bit nervous about the print process not working like a regular laser printer...
You may want to consider adding some character spacing on your control labels. Tayda's UV printing is good, but some of those characters may run together when printed, especially the "Fi" in "Filter" and "Filth". If you haven't already, make sure you subtract the brush stroke vectors behind your text as well.
