I guess if you would socket some specific parts you could switch it to other versions through that. Not a "flick a switch" thing, but more of a "I'm a bit bored of this one, I'll switch it to the other configuration" type thing?There's a pretty detailed thread over on FSB with someone who's traced all of the Joyo versions of the T21 pedals. Seems like although the topography is the same, there are enough component differences between each version to make a universal or even a dual-version impractical.
Then stack them in a super tall Hammond and run a 12PST so you can select between any one at any time.
FYP.When we do a multi PCB it will absolutely use a single rotary switch to select between the models...
I’ve heard of “C&W” (Country and Western), but what is “P&W”?I'm a big fan of the Liverpool - used it for several years in a "no amp" setting for P&W.
Praise & Worship.I’ve heard of “C&W” (Country and Western), but what is “P&W”?
Hi Watter!Suggested name:
-Leeder of the Pack (or Leeder of the Stack/StackLeeder)
-Wattering Can
That would be the best PPCB circuit's name ever."Hi Wattson, I've got some Leeds" — Sherlock Tones
