jimilee
That looks like the enclosure you can buy with the pedal, in which case, the vents are already cut.How did you do the vents?
@jimilee is right! I got the enclosure from Sushi Box with the PCB! Looks sweet, I could never do this by handHow did you do the vents?
Thanks a lot man! Being a pedal builder is the best possible professional experience for a person with OCD, hahahaMarshall branded tubes with matching colored wire pretty much tips it in for the win. Nicely done
That looks tiiigght and fun!! I’d definitely try that out!A little while ago in the "Must Build" thread I mentioned my love for the Soldano GTO and was asked if there were any PCBs out there in the world for it. I don't usually work in through-hole, but I decided to take a swing at it. Usually I make a little daughter board for the tube sockets so they can mount at a right angle to the main PCB, but mounting the whole PCB vertically in the chassis like this makes it way easier to build. I'll try to get it boxed up later this month so I can see how it fits, but first I wanted to hear how it sounds. Tayda ran out of the 22nF high voltage caps I planned to use so there's one random yellow film cap, but other than that I'm pleased with the look.
Also I'm pleased that aside from the tube sockets and the ribbon cable, every single part on this board can be purchased cheap from Tayda.
Kind of. The manufacturer insisted something was wrong with my files and that it wasn't something on their end, so I'm going to have to eat the loss and order again. I'm planning to triple-check my files and reorder soon.Any updates on the buffer board?
Thanks for the update and I hope you had a Merry Christmas!Super quick update: the AMZ buffer I have sitting around did not help at all, but the order has been placed for more Cornish buffer boards (making absolute certain to use the file from the first order, not the second) and they should be here before the end of the year. I will of course keep everyone posted.
Also for the future I'm trying out a new layout with the tubes mounted on daughter boards on headers so the main PCB is horizontal in the enclosure, which gives a lot more room for placement and routing. The prototype for that board will come in the same order as the Cornish buffers, so another thing for me to keep you posted on.
Thank you for sticking to it. I speak for my self but most likely all of us that it means a lot that you are going through the cost and time to make things right for your customers. I can see why Robert granted you Verified Vendor status.So the good news is I have a new layout for Black Eye that was laid out more carefully such that it does not need a buffer in front and operates without squealing even with the gain dimed.
The bad news is my third order of Cornish buffer PCBs are not working. I'm going to start over with the design and try to make it work. The revised Black Eye PCB will be a great option for the future, but I still want to get a fix available for those that already have boards, especially since the new layout is different enough that the enclosures will not be compatible between the two.
Unfortunately it does not. When I was doing the new layout I tried to force it into the previous version's drill layout and I couldn't make it work. It's a scratch layout, so it will not fit into the previous enclosures. Thus the big push for a working buffer board to fix all the previous versions out there.@vigilante398 do the new boards have the same drill & vent layout as the V1 boards?
