Big Monk
I’m in the process of making about 50 I/O boards right now and I thought it might be useful to show people how I’ve adapted the Tayda PCB isolated jacks for use on my board and with the Cliff ground washer.
If my count is right, I have about 300 or so units out in the wild with the Cliff washer.
I have it flawlessly integrated now but a few problems caused issues early on:
1.) It’s really meant to mate with Cliff jacks
2.) Jacks were not sitting flat onto the board with it on
3.) Modifications to the washer often caused more issues than helped.
Here’s what I do:
1.) You need to notch, score and cutout the plastic “lip” underneath the jack:
2.) Bend the plastic washer seating tab on the EMI/RFI washer:
3.) Install the original plastic washer PLUS an additional one (the Tayda jacks only come with one so I order a few hundred extras every couple batches). Fit the EMI/RFI washer so the tooth part slides just over the exposed female part of the jack:
4.) Notice that the PCB pins for the ground washer are slightly elevated. Gently bend the tab in toward the jack body:
The jack should now sit flush with the PCB:
Here’s what I do:
