Big Monk
So I’ve been playing around with ideas for getting a discrete enclosure ground on isolated jacks without having to:
a.) Use mixed jack types;
b.) Shoulder washers;
c.) Run a separate wire
Why, you say?
I’m trying to adhere to the “enclosure ground” at one point philosophy and I like that isolated switching jacks let me jump terminals to get symmetry in where the wires exit the jacks and land at the board.
So I came up with this little hack I think I may use:
First shot shows copper tape solder led to non-switching tab then wrapped around threads.
Second shot shows how discrete it is looking into what would be the enclosure and enclosure itself is simulated by the metal nut between body and plastic nut.
This setup basically mimics having a separate wire from the sleeve to ground on the board.
My plan is to use isolated jacks with threaded metal ferrules so i will have to test those out when my Tayda order arrives but I imagine this will work fine there as well.
Thoughts? Criticism?
Why, you say?
