jimilee Well-known member Sep 24, 2022 #1 Just looking at the Tommy III, what does this switch do exactly. It doesn't, on the surface, appear to be switching anything.
Mcknib Well-known member Sep 24, 2022 #2 Looks like it bypasses D4 for asymmetrical clipping so more or less routes the signal through the path of least resistance either through D4 or not
jimilee Well-known member Sep 24, 2022 #3 Mcknib said: Looks like it bypasses D4 for asymmetrical clipping so more or less routes the signal through the path of least resistance either through D4 or not Click to expand... It just looks a bit strange from what I’ve seen before. Logically, it looks like it would still be in there, but voltage wise, I guess it removes enough that the audio signal doesn’t go through there and clip.
Robert Reverse Engineer Sep 24, 2022 #4 Switch OFF, symmetrical clipping Switch ON, asymmetrical clipping (D4 is shorted by the switch, effectively out of circuit)
jimilee Well-known member Sep 24, 2022 #5 Ah, ok, gotcha. My brain was working in reverse. Thank you sir.
Locrian99 Well-known member Feb 14, 2023 #6 If I just don’t install the switch it will be the symmetrical or I could just jumper the middle pad and left pad for assymetrical correct ?
